Removing keyed ignition
dennisS
Tucson, Arizona
Anybody know where the screw is located that releases the lock assembly in the steering column? Checked the TM's and can't find it anywhere. I am replacing the dimmer and windowwasher switch and have to remove the ignition in order to access those switches. This is a M1010.
Dennis
Wildmax
Athens, Al
Hello, dennisS, yes you must remove the steering wheel, then a ring clip on the shaft , remove the steering lock plate. Then the screw in the ignition lock cylinder is accessable. You may do a search and find more info. Good Luck:D
Wildmax
Athens, Al
Also check the TM again maybe a different one than you looked at. There is a exploded view of the entire steering column mechanism. I may be mistaken but I think the dimmer switch is located down on the outside of the column and actuated via a small rod.
The window washer switch however is located inside the uppper column , I think.
Crawdaddy
Louisiana
Once you pull the steering wheel off and its lockplate, there should be a torx-headed screw roughly above the centerline of the lock cylinder on the right hand side of the face of the column. It's pretty large in diameter and seems to be made of some very light pot metal, but it pretty durable. I think it's a T15 or T20.
Wildmax
Athens, Al
TM 9-2320-289-34P, Figure 127 shows an exploded view with parts identified. Also in TM 9-2320-289-20 , section 8-9 are instructons for steering wheel removal.
dennisS
Tucson, Arizona
Thanks guys, I found it, it is a spring clip that is located to the rear of the ignition. I accessed it through a slot and after several minutes it popped loose.
Dennis
Yes, the dimmer switch is located on the outside of the steering column but the actuator housing is a part of the windshield washer switch which is inside the column and you must remove the ignition in order to access it. Nothing is easy.
txmytx_catahoula
-3
Port Arthur, TX
That's the same as my M1009. I looked all over that area for a locking screw only to find it was a "spring clip" back in the last slot to the left.
Glad you found it quicker than I did!
Jersey4x4
Absecon, NJ
the columns with the spring clip are the old style used in the 70s and real early 80s. They must have been laying in a warehouse and GM just used them to get rid of them. Most of the 1983 and newer vehicles have the screw holding the lock cylinder in.
dennisS
Tucson, Arizona
Hey neighbor...I see your rig everyso often on the east side 8<)
Alex
Well I hope you see me driving around tomorrow. Having hard time getting that ignition to snap back in. Looks like its lined up right but....oh well, done for the night try it tomorrow. Like to see your new rig, give me a call.
Dennis
