For the M1009 Newbies: Maintenance/Repairs
epartsman
Jacksonville/Florida
Water is the best as some of the solvents in store brand flushes can cause more harm then good if not totally removed from the system after using. Also remember after refilling the radiator to add some anti cavitation corrosion inhibitor which will extend the life of your cooling system. You will need to find a non a/c pickup as most civy blazers had a/c and they are different. Now would be a good time if you are thinking about adding A/C to acquire a factory A/c case however remember you will be starting down a Mod road like the one I am on which will require fabrication. I have already located a civy K10 p/u diesel with all of the A/C still intact that I will be installing in mine that will require 1 battery to be relocated, firewall cut, the bus bars moved, and some dash fab as well as a custom alt/a/c comp dual mount bracket which I will be fabricating on my own.
ARYankee
33
Benton, AR
Yeah I was leaning towards just flushing a bunch with water. I wanted to check to see if any other CUCV guys may have used something that worked really well. As far as anti cavitation corrosion inhibitor, where would I get that? Local truck stop or auto parts store? This is my first real diesel. As far as AC, it would be nice to have but I don't think that I am ready to cross that bridge yet.
epartsman
A good product to use for anti cavitation corrosion is Motorcraft VC8 which is available at any Ford Dealer for $6.90 per bottle. If I remember correctly it is 1 bottle per gallon so you will probably need 2 but that should keep you until the next coolant replacement which is every 2 years.
