Joe Gamma
- 1
- 0
- Middleboro Mass
Is the goat flasher unit a common one for all military vehicles of the era..
Thanks ..
Joe
Thanks ..
Joe
\The Goat has brake lamps that work when the lighting switch is in either the STOP LIGHT or SER DRIVE position.
The OEM blackout switch is one of the more easily found parts - since it was common to just about all the M series vehicles of the same era. I would start out by replacing the toggles with the original switch, if that is a possibility for you.\
(wince) I figured that except that my original switches have been striped out and replaced by two ominous looking toogles..
Hmmm...
Thanks Guys!
Turn the (2) 1/4 turn screws on the master cyl access panel on top of the cowl, and remove the panel. The switch is accessible from above.Well I found the brake pressure switch finnally after abit of a search and can not imagine a tougher place to access it. Has anyone replaced this switch and what angle did they come in from..
Joe
