Off the web.
Injector Numbers:
BOSCH
New #-----------Body #----Reman----Tip-----Pressure---Application
0432217081....0430211051...NA50X...0SD248....126 bar......6.2L 1982
???????????.....0430211058...NA52X...0SD253....126 bar......6.2L Long body
0432217092....0430211054...NA51X...0SD253....126 bar......6.2L Short body
0432217229....0430211054....??????...0SD304....126 bar......6.5L N.A.
0432217251....0430211054....??????...0SD304....142 bar......6.5L Turbo
0432217255....0430211054....??????...0SD311....150 bar......6.5L TD Marine
0432217275....0430211097....??????...OSD304....126 bar......6.5L N.A.
0432217276....0430211097....NA56X...0SD304....142 bar......6.5L Turbo
"bar" is equal to 1 atmosphere - multiply 14.7 psi by the number on each line to determine actual injection pressure
Delphi Injectors
6703803---6.5 T.D.
6703802---6.5 N.A.
6703801---6.2 "
Van" Short fine thread
6704001---6.2 Long fine thread.
Standyne Injectors (New)
37818 10233973 6.5L T.D. same as 0432217276 6703803
38272 10233972 6.5L N.A. same as 0432217275 6703802
