When I bought it, it was running on red diesel (heating oil), but it should have gone through all that by now. It's been ran on pump hwy diesel for weeks.have you run, or are you running any fuel other than highway diesel? How old is it?
Bear in mind that since 85/86 when these were being built, highway diesel has drastically changed. Back then, you had LSD (Low sulphur diesel 500PPM sulphur), now it is ULSD (15 PPM). This change in sulphur content, in addition to lowering lubricity of the fuel, also affects the combustion system and the fuel system. For a non ULSD engine, I would strongly recommend adding a fuel supplement with each fillup to keep your lubricity up and keep from clogging injectors.have you run, or are you running any fuel other than highway diesel? How old is it?
.... and if he added something 'non standard' it may cause gelling and clogging in the fuel system...Bear in mind that since 85/86 when these were being built, highway diesel has drastically changed. Back then, you had LSD (Low sulphur diesel 500PPM sulphur), now it is ULSD (15 PPM). This change in sulphur content, in addition to lowering lubricity of the fuel, also affects the combustion system and the fuel system. For a non ULSD engine, I would strongly recommend adding a fuel supplement with each fillup to keep your lubricity up and keep from clogging injectors.
Thanks a lot for that! That was the most detailed and well...dumbed down enough for me, that I could find by searching through here.Checking glow plugs has been covered in great detail in the CUCV section. Seems every time the weather turns cold, it's the most talked about thing. To check glow plugs, get a multimeter, remove the wire going to the glow plug, put one lead to a known good ground (alternator case is my preferred point) and the other lead to the spade terminal of the glow plug. You should have around 1.2 to 1.5 ohms of resistance on a good one. If not, you've got a bad and possibly swollen one. Another check worth trying is with all of the wires connected, check the voltage on one of the glow plugs with the key switched on (you under the hood hooked up already and a friend turns the key to RUN but not START). Anything below 12 is a good sign, over 14 is bad. Next thread you'll want to visit is Swollen Glow Plug Removal. JJandA Racing makes a neat tool for that as well as OTC 6005A. Some people loosen the plug up and just crank the truck and rev the motor till it spits out the hole but I've had no success with that method. Smoking while cranking does indicate fuel and bad glow plugs. I just replaced all 8, only 2 were working and I had the same symptoms as you.
I dont believe anything has been bypassed and everything should still be stock 24v. Thanks a lot. I'll look into the bypassing.is the vehicle still stock (24 V) or has anything been bypassed (like the GP resister on the fire wall...) has a roscommon 12V mod been done?
These details help us to tell you exactly what is wrong... for instance you got good advice a few posts above by Sandcobra164 on checking the glow plugs, but if the truck is still 24v, and the resister has not been bypassed it can fail, cause higher voltages to the plugs, and quickly burn them out, and give you volt readings higher than posted above... and this higher voltage would point you to address the GP resister --before-- you replace a plug or you'll just burn plugs out!
There are tons of threads here to read on this stuff... I know it takes time, but it will be worth it. Personally, i bypassed and removed the resister, placed the glow plugs on the 12v buss, and put in AC60G plugs... not a problem since. YMMV
And now I've learned something today!!! I've always used that one for no reason in particular. Of course, now I'll be heading out to check that theory as well!!!Only the drivers side alternator, is grounded.
Sorry! Yes, the wait light does come on. And I can hear the relay switching.you didnt say if the light came on the dash indicating the glow plugs were coming on. can you hear it going thru the cycle?![]()
