Front shackles/leaf spring brackets. Needed
Last night when dumping a load pulled away and drove off with the A frame only.
Guess when you dump you don't back up so much that the wheels are off the ground! No standing her up on the rear gate!
2510007339406 19207 7339406 HANGER,SPRING,VEHIC LEFT........... 1
2510007058969 19207 7339405 BRACKET,MOUNTING RIGHT............. 1
2510007058969 19207 7339405 HANGER,SPRING,VEHIC RIGHT.......... 1 Not sure which are the front or rears. Would need the front ones
Also need 2540011543892 19207 11675105 BRACKET AND PLUNGER................. 1
The front spring brackets where the A frame bolts to.
