Sevin7
- 9
- 18
- New Paris, OH
Did anyone block off the hole where it shows vaccum to tell if the air filter was stopped up or block off the cold start pump? I did not and was wondring if this would matter. Was also thinking about useing the line that was to show vaccum for a boost gauge.
I disconnected and plugged the air cleaner tester connection on the manifold. I also disconnected the cold start system and replaced it with a either injection. I am pretty sure it is necessary to disconnect and plug the air cleaner tester but I am not sure if it is necessary for the cold start stuff (mine leaked anyway so the choice was obvious). My plan is like you said, to use the extra connection to obtain boost reading from. I would like to reconnect my air cleaner tester gizmo somewhere between the filter and turbo but it is low on my priority list.
