Checked out MEP-003
steelandcanvas
85
Southwestern Idaho
I was out in the shop yesterday putting some parts away and realized I had not started the genset since last Summer. The batteries have been on a Battery-Minder Maintainer, so the batteries better be up, I'll check and see. Past experience has told me to crack open the fuel filter bleeders and run the pumps for a few seconds and then close the bleeders. I turned on the glow plugs for about 20 seconds and then to the start position. She lit right off, albeit running a little smoky and rough. I let go of the switch in the start position, but oil pressure had not built up enough to close the safety circuit, so I immediately turned back the start position. She took about 15 seconds to smooth out and gain enough RPM to run on her own. After letting her warm up a bit, I opened the main breaker to the house service and closed the breaker from the genset. (I advised Mrs Steel I was doing this) I now had the shop and the house being powered by the genset. She had the washer and the dryer (gas) going, along with the furnace (gas) and some lights on. I had all the lights on in the shop, 175 watts X 6, an 8 foot fluorescent, a 250 watt baseboard heater, and started my 5 HP air compressor. She barked a little when I started the compressor, but came right back up to full RPM quickly. Without the compressor, I was running at 25% load according to the meter, with compressor, I was right about 50% load. I ran the genset for about 30 minutes and I'm very happy with it's performance, it will clearly be a trusted friend in the event of a power grid outage.
Grega
St. Paul Nebraska.
It scares me when it takes so long for oil pressure to build up, especially after an oil filter change. I converted to a spin on oil filter a month ago and havnt started the generator since then. But I hope the spin oil filter retains oil better than the canister type.
RJM27
26
Burdett NY
Last week I put my Mep002A to test, what a great feeling, glad to have one. How do you hook up the battery maintainers???????? 24-volt. Also parts I got from Jerry(storeman) work like new?????roflrofl
steelandcanvas
85
Southwestern Idaho
I removed the alligator clamps from the battery maintainer wires and installed a NATO plug. Works on the Deuce and the genset. Or you put the red + (goes to the starter) on one battery and the black - (goes to the frame) on the other battery. Don't make any connections to the "dogbone".
Yeah, I hear you. It's kind of hard to hang on to that switch in the start position, after its already started.
