out of the TM
this out of the TM
TM 9-2320-289-10
2-14. TOW A TRAILER/AIRCRAFT
a.
b.
c.
Towing Capacities of CUCV Models.
(1)
(2)
M1009. Equipped to tow M416 Series 1/4 ton trailers with maximum towed load
of 1200 pounds for both cross-country and highway travel. Load on tongue should
not exceed 100 pounds.
FA1008, M1008A1, M1028, M1028A1, M1028A2, and M1028A3, Equipped to tow
M101 Series 3/4 ton trailers with maximum towed load of 3100 Ibs. Load on tongue
should not exceed 300 Ibs.
Guidelines for Towing Aircraft Which Exceed Maximum Towed Load Weight.
(1) Speed will not exceed 5 mph.
(2) Truck will be operated with transmission in low range (“ 1”) and transfer case in “2H.”
(3) Gross load will not exceed 10,000 pounds for M1009, 15,000 pounds for M1008,
M1008A1, M1028, M1028A1, M1028A2, and M1028A3.
(4) Tongue load will not exceed 100 pounds for M 1009, and 300 pounds for M1008,
(5) Operation will be on a level, hard surface.
Guidelines for Towing a Trailer on Hills.
(1) When going up or down long, steep hills, downshift transmission to lower gear range
and reduce truck speed to 45 mph (72 kph) or below.
(2) if you must park truck with loaded trailer on a hill, follow these steps:
