STrider3
- 0
- 1
- Leesburg, Virginia
Yesterday I installed the two pull cord air tank valves that allow one to drain the water from the air tanks without crawling the truck. When I opened the valves to drain them or let the air out a small amount of an oily mixture came out so I am asking if this is normal. It was the inner tank. Also I opened the valve with the truck running and a large amount of water came out of the inboard tank. It took about three charges to get it to where no water came out with the air. Is this normal? I hope that somebody will tell me this is normal just like the last thread I started about the rear axles not lining up. That was stupid. I hope this thread is not. Also hoping all of you have nothing better to do than answer noob questions. Thank you.
