Lonesome715
- 25
- 48
- Columbus, GA
I am now addressing a very nasty fuel system on the deuce I am trying to get running. The tank was full of bad fuel when I got it. I have drained the fuel out but the inside of the tank is nasty with slimy build up. I am assuming the rest of the fuel system is just as bad. I have several questions before I dive into this portion of this resurrection.
First, I have never gone this deep into a deuce. In the last photograph will some one please identify the parts? Which one is the fuel pump? Also, how do I know if the fuel pump is any good? How does it work, is I electric, hydraulic, or pneumatic driven? Can I tear it apart, clean it, and reassemble it, or is it the type of part I throw away and replace?
Next, there is a crimped line that is stick out of the frame. I have a red circle around it. What is that for? Also, what is the empty threaded hole for? Is that threaded hole and that crimped line suppose to connect?
What is the round thing at the rear portion of the tank? Is that for the fuel gauge?
What should I do about the IP and injectors? Will clean fuel from the rest of the system clean them, or do I need to tear them down as well?
And the last question for now, I am assuming the sending unit the large round thing close to the opposite edge with the large fuel line coming out of it. I know that thing is covered in gunk. Is that something I can clean and reinstall or is it a replace and toss part as well?
