Dear Santa Claus, I want for Christmas New 6 hole aluminum 6 slotted wheels ....
Dear Santa Claus, I want for Christmas New 6 hole aluminum 6 slotted wheels for my M35A3. They should look like old keystones or cragers.
I want them with the same offset as the original wheels.
I want them with a deep drop center in the rim between the beads so I can mount them with soapy water and tire spoons and a rubber hammer.
I want them to have the pads for mounting th4 CTIS stuff, but I want to add a one way check valve between the CTIS and tire so I can inflate the tires up to the 80 psi they are designed to run.
I want the rims to be machined for MPT Beads and capable of inflating to 90 PSI.
I want to continue t use the stock Michelins that are on the truck. I want a second air fitting boss on the rim so I can add a dump valve. I been good Santa Claus so will you give me 11 of these? Please
If I could get these wheels I would put a set of rockwells under a CUCV just to wear out my excess tires I have.
