Cummins IP part# question
5tondeuce
Hampton/New Brunswick/Canada
Hey guys,
So i got my 813 running today that has not run in many years. Its runs great but is spraying out fuel from the injector pump front cover where the gasket is. I got the part #s from the TM,s for the gaskets. Are these part #s military specific numbers or cummins part #s, Here they are
100764 and 3035053
Thanks
Chris
ODdave
lansing michigan
Parts for the PT pump should easily be available in the civi market
To make it easy, as pm's wont mach. Print off a pic of the TM with the part in need and take it to the dealer with you.
simp5782
Feo, Fuerte y Formal
9,333
Mason, TN
You can check your local cummins shop. Or there is one on ebay. Just search "100764 cummins gasket" or just the number and it will come up. Sorry cant post the link here.
simp5782
9,333
Mason, TN
No problem. You can also google search 100764 Cummins Parts and you can actually get the whole rebuild gasket kit for the IP in case you need spares.
