jdeoliveira74
- 3
- 0
- wilmington nc
At my pick and pull here they have a 91 burb can I use the front and rear springs to get some lift on mine??
Will they bolt right in?
So they are the same as the blazer? so what your saying is get two sets and pull them apart and make my own. I have never rebuilt springs what kind of lift should I expect per leaf added?I believe the fronts ARE the same.
and you can add a leaf or three, IF you can find a spare set and add them in
yes rear springs are to long.
73 - 91's?
yes perhaps earlier models, but I have owned several of these and they all have the same length rear springs - I believe they are 58" between spring perches - at least that's what I have found over twenty years of owning these silly beasts
but I could be wrong about that.
