not only is that winch about as slow as all electric winches, i'd bet that you could buy a Garwood and convert it to hydraulic drive for less money than buying just that winch.
i'm not hating, just that at higher line pull levels (over, say 12k lbs) i think electric quickly and exponentially deviates from the performance advantages of PTO or Hydraulic (mainly hydro).
think about it this way: if your truck was mired and took 15k lbs of line pull (not unreasonable, and likely too low considering a 5T) for 25 feet of truck, it'd take over 4 minutes at over 150A draw (1st layer numbers; higher layers result in higher Amps). that may be within the duty cycle of the winch, but that's hella-hard on your charging system / batteries.
a PTO winch (and even hydro-converted) will do the same in 1 minute, with continuos duty cycle, and an additional 100' of line.
just sayin'...
