RedbeardTheZombieHunter
- 3
- 0
- Darrington, Washington.
After studying and reading till my eyes blur, here's a suggestion for the crowd that wants to bob a deuce. I was looking at various threads and reading the opinions on the best VS. the cheapest way to do a bob job that is safe, durable and reliable. After much banter about the pros and cons of using M105 springs for the availability factor as well as cost of a set of deuce front springs, you have the option of using lift blocks between the springs, or cutting the section of the M105 chassis in front of and behind the springs and mounting that section under the deuce frame. OK fine, then came the discussion of weather to weld, bolt, rivet, or plate the two frames together and then it hit me. Why not leave the bogie plates riveted to the frame and use those to bolt the trailer frame section to the truck frame? So I gave a call to Mark A.K.A. "Hundy" at 100Dollarman in Lucerne Valley California, as he's done a bunch of bobbers and one of which used the trailer frame section to mount the springs and axle. When I dropped the idea on him and asked if he could think of any reason why this wouldn't work or be feasable, the first words outta his mouth were "Hmmm, I never thought about that but I can't see why it wouldn't work.". Does anyone else have any input on this? I'll be making the 500+ mile journey to get my truck next week and when I get it back, I'll be diving into a bob job and I would like it to go as smooth as possible. (obviously!)
Any input or advise would be greatly appreciated!
LET THE BRAINSTORMING BEGIN!!!!!
