jimm1009
- 70
- 48
- Louisville, KY
Did a search and for and found one thread from 2007 for the question.
The front motor mounts for a M1009 CUCV are different than a civilian K5 Blazer with a gas or diesel.
The NAPA number is 602-1251 for the civlian truck and the CUCV (Chevy number is 459021) but the bolt pattern for the three mounting bolts to the frame ears are slightly smaller than the patttern for the NAPA mount which they say fit both engine types. More specifically the bolt circle is smaller even though the bolts are the same size diamter and length.
If you install the civilian motor mount using the two lower bolts, the upper bolt will not fit and is about 2/3 bolt diamter off. The NAPA mount is slightly too long.
Does anyone have a NAPA or other brand part number for the M1009 forward motor mounts? They said that right and left are the same number.
On a side note, I beleive the rear mounts are the same as the 83 & 84 civy unit.
