hairtrigger
- 0
- 0
- Oregon
Yup, 44 out of a 3/4 ton suburban, was 8 lug. Used spacers to clear the rim.the 44 was availiable in 3/4 tons with 8 bolts![]()
Had I known the wife was going to want to tow things, I would have rebuilt my 400. It was starting to slip, so I put the 700 in. It was a fresh rebuild, in my suburban. I had a local do a heavy duty rebuild on it, with a large cooler, and the correct torque converter. I am hoping with the lower gears, it wont stress the tranny to bad.I have been thinking of doing axel swap on my m1009 maybe 373 or 411 front and rear lift and running 37's also but keeping the th400
did you make the roof rack?? Or was that a purchase? Nice truck
Turbo, intake, and manifolds where a Craigslist score. $250. It was everything else that nickle and dimed me to death.Very nice turbo set-up where did you find it at? And how much did it set you back? As far as a 700R4 I have had them in many cars and my wife's suburban, and they aren't all that great of a trans. Really need a large trans cooler when towing.
Or rebuild the the K30 and have both... you can drive the socer mom thing and your wife could drive the truck lol..
do you have any more pics of it? I want to do one myself something that free stands so I can remove top and install soft top too !
Thanks, I built it myself, and is still in the works. If you look close you will see it is not even painted in most spots yet.![]()
Even IF you choose to rebuild the K30 (you got that at auction last summer, right?), are you going to use the red lights in the grill and on the top?
if not, I'd LOVE to buy them from you. If you are interested, send me a PM
I bid on that truck and I believe it had a companion truck in the same auction - it just got too rich for me - but that setup - manual with the heavy axles... seemed like an ideal setup for either a camper or tow vehicle
LOVE what you've done so far, will keep an eye on this one
I will get some more pics later. It is a stand alone, so I can remove the top. It needs some work still, just like everything else on the **** thing.do you have any more pics of it? I want to do one myself something that free stands so I can remove top and install soft top too !
Not yet. Will later today.A properly built 700 with the red clutches and upgraded drums and a Trans-Go shift kit is a VERY strong transmission. Especially with the 4:56's I don't think you will have any problems at all. Did you check to see if the front rear was a locker?
Rick
