Wanna see a m715 d70 'correct" power lock
bcowanwheels
KINGSPORT, TN.
m715 axles rebuild & d70 'correct" power lock
THOUGHT you fellas might like to see a correct (.500 or 1/2" offset) m715 dana spicer 70 series power lock 23 spline ( 2 piece axle gears) . these things are extreamly rare. they havent been made in over 20 yrs and there is no parts left for them anywhere except for the clutch packs. dana spicer only has steel/steel clutches now as they lost there fiber clutch mfg. heres a N.O.S unit on the left, stock open carrier in the middle and a p/l carrier half I,am rebuilding on the right. also a set of axles I,am rebuilding for a fella who wants power locks front and rear, 4.56 gears, lockout hubs along with normal complete strip down and bring back to new spec's axles hub to hub. A power lock is alot better for a m715 that see alot of highway miles as it dont have the harsh characteristics of a locker in the rear so tire wear is about 1/2 compared to a locker. in one of my m715's i only got 9k miles on a set of new rear tires and I knew to let off the gas going around corners, enjoy. more to come on this.
bob
spicergear
29
Millerstown, PA
I may be mistaken but I think the offset is the necessary change from 5 series to 4 series gearsets. I may be off on that though...
Nice part collection Bob. I still have, I think, two sets of stock axles kicking around and some other odds and ends.
ODdave
41
lansing michigan
Nope, 4.56-7.17 all use the same carrier
ODdave
41
lansing michigan
Im curious as whats so "rare" about this? I have a bunch of pwr-loc's (20 or so) There not that rare. Is it the 23 spline part? I have 23 spline side gears for the pwr-loc if somone is interested.
bcowanwheels
KINGSPORT, TN.
Fellas, the m715 dana 70 axle is danas first design in the 70 series and the carrier along with the ring and pinion gears are specific to this design 70 series. It takes a 1/2" or .500 offset carrier and ring + pinion gears. The newer dana 70 axles all use a 5/8" or .625 offset carrier and ring and pinion gears. The m715 is a critter of its own and nothing newer will work related to 5/8" offset components. FOR MORE INFO ON THIS DO A SEARCH ON M715 REAR AXLE SPECS.
bcowanwheels
KINGSPORT, TN.
Got a little more work done, 2 coats of primer, 24hrs drying time then 2 coats of flat black. Gonna refurb the 2 power locks monday. Will have detailed pic,s of p/l's very soon. Got the clutch packs soaking in friction modifyer now as dana recomends.
Bob
P/S LIKE 2 OF MY PUPS ? BLACK ONE IS PAL AND SABLE ONE IS BUDDY BODINE !!! LOL THERE NAME TAKERS AND HEART BREAKERS LOL. THE YOUNGEST OF 9 I HAVE.....
bcowanwheels
KINGSPORT, TN.
I have a bunch of 4&6 bt engines. I use them in m715 swaps aalso i remanufacture them for people. I bought 35 at 1 time a while back. Now i,am down to like 8-10 of them. They dont last long
bcowanwheels
KINGSPORT, TN.
a few more pic,s added. FYI on cleanning up m715 brake drums, ALWAYS turn drums "on the hubs" and tighten all lug nuts tight installed backwards( bevel out) to snug drums to hubs. this eliminates drum chatter and ensures trueness between drum and hub. there is no need to remove drum from hub and if you do mark drum and hub so you re-install it exactly as it came off. m715 hub-drum relationship is very touchy and they dont like to be messed with. jmo
bob
also power lock now installed in rear.
bcowanwheels
KINGSPORT, TN.
Finished up completely on the rear axle refurb. Heres the new coated brake lines and rubber flex line. Sure is a bugger makeing them to form to the axle like the originals and still allow for the 2 offset u-bolts. also finding the correct line clamps was a job also.
Bob
bcowanwheels
KINGSPORT, TN.
Heres some pictures of front axle. The carrier and pinion bearings was plum shot. Worst i,d ever taken out. All the rest was excellent inside. Go figure.....
Got the 4.56's and power lock in along with grade #9 carrier bolts also new knuckle felts and seals, inner axle seals, hub seals, brakes done, drums trued up, grade 9 bolts custom made for lockout hubs, new brake lines just to mention a few things.
onegmjack
Kingsport TN
Looking great Bob.Bob you pointing out the differents in the rear and front differ.Make me think of Fred Trent,he knew them little secrects,like you do.GOD Bless You.Dwight
ODdave
41
lansing michigan
Dumb question, but you didnt recently buy some from a guy in michigan did you? He said he sold them to somone in TN.
bcowanwheels
KINGSPORT, TN.
no, only fellas I,ve reciently talked to from michigan was concernning a m715 engine. also a fella from detroit who I,am helping install a set of 4.56 gears, power steering & correcting a problem with his sbc engine adapter.I try to help everybody I can on things. I get calls from all over the U.S. and other countries as well everyday.
bob
kvflyer
Fernandina Beach, FL
Bob,
Both of those axles look terrific. Are you building them for your "Keeper" truck or for someone else? Nice work and I am sure the dogs are "Helping" you whenever they can.
