Ripcord01
- 9
- 0
- Waldorf ,Maryland
Cobra is a good middle grade cb. I have dual antennas mounted on my headache rack.
I like your headache rack, where did you get it and what is it?Cobra is a good middle grade cb. I have dual antennas mounted on my headache rack.
If you are getting a Cobra, go with the 29 LTD and then take it to a CB shop. Have them put in big finals and peak and tune it.
Thank you. My friend who is a Certified Welder was bored and made one for his truck, I saw it and liked it, so I asked if he would build me one. The rest is history. The truck is a 2012 Toyota Tacoma. AC cabIt all depends on what you want. Do you want dual whips? Do you want a single looonng whip? do you want a 3-4ft magnet mount or a fiberglass whip? Do you want to talk all over the globe, or across town with your buddies? Do you want the cb to match the interior of the truck, or can you settle with a stripped-down across-town radio? <-----I recommend the Cobra 19 for this. Its ~$40 and looks almost factory. I have this in my Ranger.
If you want it all, there is nothing better than a Cobra. The 29 model has many variations, but it only depends on how many gizmos you want.
Check out the cobra site for cb models.
1. does it need to get tuned and is it worth 100 to 150 bucks to do it?
2. what Coax and antenna?
3. Where should I mount the antenna on my truck?
HUH???? why is that? Not doubting you just really confused about the idea? Would this also be the case if dual mounted like Islandguydon did? I would be putting it on my deuce w/cargo cover(not a box like he has)Just keep in mind, if you put the antenna on the front of the truck, the majority of your transmit signal will go to the rear. If you mount the antenna in the rear, your signal will go forward.![]()
