STrider3
- 0
- 1
- Leesburg, Virginia
When I bought my truck I envisioned myself being the rescuer of in my town of Leesburg, where I roamed the 2 foot snow covered roads pulling hapless Ford Focuses from the ditches with my winch and 10 wheel drive M35 in perfect Ted Nugent style.
Well, near zero snowfall so far this year but keeping with my new found Knighthood I did have the winch operational just for the sake of learning how to use it the other day. I pulled a fallen tree up a hill about 50 feet.
Easier to use than I thought it would be and I was surprised that it is a perfectly safe operation so long as there are two people doing it. But I digress as none of this is my point...
Now there is a 3 inch pool of gear oil exactly beneath where the driveshaft u-joint enters the winch. I am now going to order a winch seal kit and fix it. All of you here on the board make these repairs seam easy and I have the utmost respect for the persons here that state that there was a noise in the xmission so I took it out and fixed it as if there is only one bolt needed to accomplish this monumental task.
I will report when I finish this minor of things comfortably knowing that all of you have my back. Steel Soldiers rock.
Thank you.
Thank you.
