m274 needs timing
1,163
This is probably for the 2 cyl engine only, but it's the best I can do.
Motor Pool
There is a guy here who has a 4 cylinder Mule and is pretty knowledgable but he doesn't post much.
TKRESS1
HANOVER PA
Need help
Looking for tips on timing the 4cyl motor. We have it close but can not get it right. Let me know if anyone can help.
1,163
Austringer is probably the undisputed expert in the 4 cyl realm. Hopefully he'll chime in within a few days.
natem
17
freeland/michigan
If you have the correct TM study the photos, the text is misleading. Your best bet is to use a vacuum gauge. I don't know if a standard timing light will work with a magneto.
crorlo
Houston, Texas
Can it be done?
Can you install the magneto in a two cycle engine without taking the governor off to align the V marks, as long as the impulse coupling clicks between 18 and 28?
doghead
4 Star General /Moderator
1,193
Did you mean two cylinder? Did you pull your mag, but not your governor and now you need to re-install it?
The answer would be yes, but you need the gear installed from the governor side(and to see the marks), so if your gear is installed, you simply have 2 choices to install the mag based on the pin drive holes.
The governor can be removed in about 3-4 minutes.
To do it correctly takes about 7-10 min.
TKRESS1
HANOVER PA
Got it
We got my 4 cyc engine running smooth. Just need a little clean-up and we will be ready to install. Thanks for all the help.
