Fire extinguisher
tigger
Medic.
50
Butler TN.
If you happen to have a fire extinguisher mounted in the bed of your puckup. that the safty pin fell out of DO NOT hit it with a piece of firewood, because it will hit it the handle and it will be pointed right at you when the firewood hits the handle perfectly to set it off and you will be covered in white stuff. and your daughter will be rolling on the yard laughing so hard she will pee her pants. And grandma will make you strip out side befor letting you in the house. Just dont do it!!!!auaaua:oops:
axlr8
Rushford MN
haha! I had the same sorta thing happen when using a water one in a demo....and the fitting that holds the hose on broke off.....yes.....i was wet.....
and it was about 50 years old...
tigger
Medic.
50
Butler TN.
Sorry no picks. And i did not get it in my eyes or mouth. Took a hose to the inside of the bed to clean it out. wonder if my fire wood will burn now?
steelandcanvas
85
Southwestern Idaho
Hey Tig, Thanks for the heads-up, I will from now on keep my firewood and my fire extingusher (with pin removed) in opposite corners of my truck, can't be too safe you know. ;-)
SMOKEWAGON66
21
California
Hey at least it wasnt inside the cab of your truck...Guy in my unit in Alaska threw a drip pan behind the seat and it landed on the fire extinguisher....purple K all up in the cab of his M1074.
wdbtchr
St. Louis, MO
Make sure you clean it up as soon and as completely because it is terribly corossive. I'm not saying how I know this, great for fire supression otherwise a mess.:roll:
John S-B
951
Ostrander, Ohio
Should have added that they do make plastic ties that break easy to hold the pin in. You can also use a bread wrapper or garbage bag tie. Or any thin copper wire. I've even used a piece of electrical tape to keep that pin in. ESPECIALLY if it's in a cab or crew compartment. Just bouncing up and down the road without a pin can be enough for the handle to slowly bleed off pressure. Then you got a big ol' paperweight.
zout
154
Columbus Georgia
OK - I call BS on a scale of 10 on this one - Tigger outta know without pics its worthless. Without visual effects its
hard to laugh with you - or at you looking like the Pillsbury Dough Boy.
