Looking for a particular Goat picture.
BillIdaho
Caldwell, Idaho
Once upon a time while I was visiting internetville, I saw a picture of a Gama Goat with an unusual antenna mount. The antenna itself was the common AS1729 VRC, along with the MX6707 matching base. The unusal part was specifically where it was mounted. The antenna appeared to be mounted on the rear fender, not on the carrier-where they were normally mounted. The picture as I recall showed the Goat looking at it from the driver's side front. (What with my advanced age, it very well could have been from the passenger side, but either way, the antenna was mounted on the rear fender.). I have a tree's worth of TM's and none mention that particular place in regards to placing an antenna.
Anyone know of that photo?
Gamagoat1
39
Kiowa, Colorado
Bill,
TM11-2300-372-14-4 shows a RT 524 0r RT 246 mounted on shelf assembly SC-D-446385 in the dash where the circuit breaker panal goes. The antenna for this is mounted on the left front fender(Drivers) and is made up of the antenna bracket assembly SC-F-446392 and antenna AT-912 /RC or AS-1729/VRC.
Also mounted in the shelf (under) is a R-442/VRC with it's antenna, Mast base AB-15/GR mounted in SC-D-446381, all mounted on the tractor's right rear fender.
This TM is instructions for installing installation kit MK-1245/VRC in M561( Cab Mounted Radio set AN/VRC-12 or AN/VRC-47, and has drawings only. No pictures to send ya.
goat whisperer
-23
Bremen, Germany
Bill,
Mike, the Gama Goat encyclopedia :jumpin:
