Recs for Transmission Shop in GA?
lowside
Atlanta, GA
A couple months ago my M1008 started making occasional horrendous grinding noises when trying to start the truck. After reading a bunch of threads on starters coming loose and needing adjustment I was hopeful that would be the extent of my problems, but alas, no such luck. I finally pulled the inspection plate this weekend and looks like my flywheel has a section where the teeth are chewed up pretty badly, not the news I was hoping for but at least I know what I'm dealing with now.
I've been planning to do a transmission swap on the truck anyway so I have overdrive, leaning toward the 700r4. Now that I know I need to replace the flywheel sooner rather than later I figure I might as well get everything taken care of at once. My question is does anyone have recommendations for a decent CUCV friendly transmission shop somewhere in the vicinity of Atlanta that could do the work for me?
Thanks in advance for the advice,
-lowside
zout
154
Columbus Georgia
Lowside - I saw your thread so far go unanswered.
I do not know of any reputable automatic trans shops in the area. I have personally dealt with two of them and to say they least they were worthless theives (I will not mention or pm their names).
Hope the best of luck to you - but whovever you go to - thoroughly check out their former customers and their satisfaction with the vendor.
Matt65
Alabama
WELCOME!
I recently replaced my flexplate (flywheel). It is not all that difficult if you decide to do it yourself. If you were to do this yourself there is a lot of information here to get you through it. The trans swap I would imagine has been docutmented as well.
Before you change the flex plate I would try to get a good relative position to the starter. Shimming the outer bolt alone will move the starter closer, inner/both will move it away. That way when you go to your new part you will reduce the likelyhood of re-grinding it as well. A new starter gear may be due. I used a paint marker to better understand the meshing of gears: starter to flexplate in addition to the TM spec'd clearance. Both showed my starter was too far away.
Be sure to use New Factory GM starter bolts @ correct torque with the correct front starter brace. Do the DogHead Modification to your starter relay.
lowside
Atlanta, GA
Thanks everyone for the replies so far.
zout, I'm in total agreement with you here, as I've been burned before myself. Unfortunately waaay too many mechanics these days can't or won't perform the quality of work I expect. I'm happy to pay a bit more for someone who will actually do things right but it's hard to know what you're getting into until it's too late most of the time. Hopefully someone has a shop they trust that they can point me to :smile:
SPECIALTYLC said:
You will also need a new transfercase, as the 400 and 700 dont interchange.
Thanks for the heads up. I think changing the output shaft on the 700r4 is also an option right? This is part of what I'm hoping to save myself from if I can find a reputable shop: I'm sure I can figure it out eventually, but I suspect I won't like the extra time and $$$ it's going to cost me to blunder through it on my own :lol:
WELCOME!
Matt, thanks for the advice/encouragement. Most stuff I'm not afraid to just tackle myself and I'm fairly confident that I could figure this out (eventually, with a few inevitable hiccups and detours along the way). Mostly, it's that the time I'd have to sink into this project is a bit more than I'm ready to commit to at the moment. That said, I haven't entirely talked myself out of just doing the project myself yet, if I can't find a shop I trust to do the work I'll probably end up biting the bullet and doing it myself :roll:
The doghead relay mod is next on my list of things to do, honestly I'll probably end up fixing that before I sink the money into the transmission swap. I suspect that the failed relay may actually be the root cause of my flywheel problems. The relay was gone when I bought the truck, someone bypassed the starter system through a toggle switch on the dash which controls the starter now. The relay must have failed at some point in the past and if it stuck with the starter going that might have been the beginning of the end for the flywheel. I've got the relay in hand, just need to take an hour or two to get it installed.
-lowside
glaser06
Red Stick, La
I've had good experiences with Hi-Tech on Buford Hwy and Precision Transmission Service
1571 Donald Lee Hollowell Parkway. Neither have been for my CUCV, but I had a TH350 rebuilt for a 'vette at Hi-Tech and several TH400s and Powerglides at Precision. Don't let looks fool ya, neither in a very "upscale" part of town, but both seem to know their stuff.
