M37 Vietnam Resto Build Thread
Black Ops
98
Colchester, VT
I bought a 52 m37 back in December and have been working on tearing it apart since then. Now that the weather is nicer I figured i'd start on thread on the restoration.
Not going for a factory look, it will have some "custom" touches like silver gauges and controls in the cab, pin stripes on the wheels, and west coast mirrors, etc:jumpin:
Here's some recovery pics.
Carter
Delta, Pa.
Nice truck to start with, you have made good progress. Will follow your work with much intrest.
Looks line someont threw yellow paint at the back of the cab :wink:.
Black Ops
98
Colchester, VT
Today we dismounted all the tires from the wheels. The tires are all dated from the early 1950s and were retreads so they are being replaced with some used NDTs I bought.
We also got all of the wiring pulled and started sanding the paint and cutting out rust. All the brake drums are now off, so we'll try to get the brakes done soon.
vtdeucedriver
39
Vermont
Well, at least one is leaking, and only two of the shoes are moving, and I found a huge empty bottle of Dot 3 under the seat...
Here's a pic of the lightswitch and instrument cluster with two temp gauges;-)
One of those Temp gages better become a pressure gage........Prefferably the lower right one.
Somewhere Ive seen this silver trim before:wink:
Kasper31
South East Michigan
It looks like you're getting off to a great start, as you may allready know there's alot of info on this S.S site that can help you if needed. There are no dumb questions here, just ask .[thumbzup]
Black Ops
98
Colchester, VT
Didn't get too much done today, just a lot of sanding on the cab and degreasing the engine. We have to weld in cab corners and a few holes that were drilled, then it will be painted back to OD green after the body work is done.
Black Ops
98
Colchester, VT
Where on the frame? Mine was folded in fours, tucked on top of the gas tank, under one of the straps. Yours looks very similar to mine.
Mine was folded and stuck at the brace between the frame and the rear crossmember that the bumperette bolts to on the drivers side.
majorhitt
Dallas Pa.
Weld in the cab corners? The pictures I saw the corners look pretty good. I wish mine looked that good. Keep up the good work and the photos coming.
