jerseyjeep2003
- 2
- 0
- Gloucester City NJ
AAARRRGGHH, Master cylinder rebuilt, Airpack & slave cylinder rebuilt, added remote reservoir, and pressure bled system. Nothing, nada, nunya, pedal still goes to the floor. I had massive amounts of air at the wheel cylinders, but finally got straight fluid under pressure. But still no pedal. OK, thought about bench bleeding the master, but, it should have been OK since I bled it at the air pack. I then discovered a missing copper washer at the output of the master cylinder. Thought that was the problem, NOPE!! I am at wits end here. Should I just continue to bleed the system, or put on a different master cylinder I have ( it was oozing fluid even though it was new)? Any thoughts from those smarter than I?
I had another post on rebuilding my air pack, but it seems to have gone dead, so I'm making a fresh post for some thoughts.
