I am re-doing my cables for the battery/starter. The present battery-to-starter cable has an Anderson connector in-line to facilitate removal of the starter. I have since found that there are also smaller Power-Pole cable connectors so I was going to install one at the lower end of the Purple starter cable and a newer single connector on the Battery cable above the chassis cable clamp.
I thought I would replace the Purple cable from the fuse block- front of firewall, all the way to the starter solenoid. I believe the cable is 10 gauge; but I was wondering if there was any reason to go larger- is this purple cable delivering 12 volts or 24 to the starter solenoid?
