does anyone know what this steel plate is for?
pctrans
19
Bradenton, FL
Good question. Can't say as I've seen those plates on any of the deuces I've done. Do you have the complete serial number? Off the left front frame section, near the shock?
TJP
PHX/AZ
HAVE ID #AC03471-532-108993
Cant see serial # on the frame. Is it visible with out opening the hood?
WolfWalking
Arlington, WA
How the about simplest answer, it could be the only shim they had to attach the other bracket with. That or a nice 500 dollar "Bracket, Special, one each" to up the cost of the vehicle.
jesusgatos
on the road - in CA right now
On my M109, there are brackets that extend downwards from the box and keep it centered from side-to-side. Those plates keep the from contacting the frame. Maybe your truck had a box on it at one time?
TJP
PHX/AZ
My truck started out as a m109, but when I got it the box was already taken off. I think you have figured it out the plates must be there to protect the box and frame from improper wear.
Thank for the info.
Tim
DUECE-COUPE
Scurry. Tx
Plate ID
It could be a frame protection plate. Some deuces were dumps, and it looks Like the plate is in the right place to protect the frame from the dump bed guides as they came down after dumping their load. Check the age of you truck. The Army being what it is, probably contracted ALL the truck frames to be the same, so they could be configured any way they wanted them to be.
gringeltaube
Staff Member
2,690
Montevideo/Uruguay
Older M109's (gassers) also have these brackets which are bolted to the box subframe only; but they are spaced out a few mm and there are no plates on the frame.
Adding these plates must have been just one of the many "upgrades" from sometime during the 70's.
G.
11Echo
96
CT W. R.
This truck was not a deuce dump. The deuce dump had a different trunion plate and reinforcement plates rivited along the outside of the frame rails.
The second pic shows the tipper trunion plate and rivited side piece.
