Rattlehead
- 3
- 18
- Michigan
Looking at my air cleaner housing, I see a 3/4" diameter pipe outlet on the back of the housing pointed towards the firewall area. Am I correct in thinking that this is a backup air intake path in the event the mushroom gets blocked with snow or other crud?
At idle, the engine is pulling a noticeable amount of air in through that pipe. And, judging by the massive volumes of hot air that gets forced up through every opening in the floorboards on the highway, I would say that pipe is sucking a lot of hot air when driving down the road. Just thinking of plugging it, at least in the summer time.
Also, I would like to turn the mushroom 90 degrees so that I don't have to worry about clearing out all of the snow. Those that have done so, what did you use for pipe?
