Deuce Multi compressor belt adjustment?
broadsword71
SW Florida
1971 Bobbed deuce Multi fuel. I noticed the compressor belt is slipping a bit and has some slack in it. It just started after a day of hard wheeling. I think it stretched a bit. I noticed that there is no visable adjustments to tighten the belt. What is the deal with this? Seems foolish that the military wouldn't have an adjustment. If anyone can help explain this I would appreciate it very much. Its my first deuce and am learning a lot quickly!
THANKS
SEMPER FI
AceHigh
31
Lake City FL
Special wrench on the air compressor pully, it screws the pully in to tighten and out to loosen. It can be done without the wrench but it is harder. Also I think there are a couple of tightening bolts. Pretty simple.
Josh
12
Portland, Oregon
On the compressor pully there are two bolts. Remove the two bolts. Get a pair if wrenches big enough to fit on the two haves of the compressor pully. Counter turn the two halves to tighten or loosen belt.
goatijoe
fort mill sc
Use plenty of a good pentrating oil on the outer half before starting. To tighten turn the outer side to the drivers side to tighten it up. Don't worry it will brake free with anough Armstrong they tend to rust up on the adjusting threds.
Sent from my PC36100 using Tapatalk 2
broadsword71
SW Florida
Man thanks guys! I actually said to my brother yesterday it looks like the pulley should squeeze like a one way clutch on a go kart.
broadsword71
SW Florida
Here is a link to all of the free technical manuals covering your truck. The Deuce TMs - Steel Soldiers::Military Vehicles Supersite
These are a free download courtesy of Steel Soldiers and can be very helpful in working on your truck and in the learning process of maintaining it.
Thanks I did download and spent about 2 hours looking through it before I posted for help. I could not locate compressor belt pulley info. Impatiently I posted for help! Lots of material to look through. Appreciate your help
Floridianson
2,522
Interlachen Fl.
You can also try having the two bolts lose and if you threads are good shape just start the truck. It tighten itself for me that way once.
Recovry4x4
LLM/Member 785
1,824
GA Mountains
The problem with deuce TMs is there are too many. I always instruct folks to get the TM 9-2320-361-10 (owners manual) and TM 9-2320-361-20 (unit service manual). Without understanding what the TM numbers mean, it's a daunting task to find anything. For the deuce there are 2 popular series, 209 and 361. Note the 361 in the manuals I've listed. For info junkies you can get all of them but these 2 are must haves for entry level deuce knowledge. If it ends in -10 its an operators manual. Ends in -20 or -24, its unit maintenance. If it ends with a P it's a parts manual.
broadsword71
SW Florida
Thanks guys for your help. Took me 15 minutes to tighten. I took the bolts and used a nicely round air chisel not to ruin or damage the nut and rapped it right around. Worked perfectly with no damage. I'm going to carry that chisel on board with my other air tools.
plym49
171
TX USA
That was clever. I think we all just learned something from you. (Although you are better off just getting the correct wrenches - they are inexpensive enough, and if the belt breaks outright your trick might not work since you will run out of air).
73m819
328
gainesville, ga.
Where is the EMG. for this HELP (911 call) post, do not say HELP as a title, members think it is a 911 call, NOT I have not read the correct TM statement, next time say how do I a adjustment for my air compressor belt
broadsword71
SW Florida
Man GREAT INFO! Yes Sir it is daunting...This helps me tremendously for future break downs
broadsword71
SW Florida
Ha sorry about that. I just copied others that posted looking for assistance. which is what I will post from now on.
broadsword71
SW Florida
Well I'm a Marine, IMPROVISE, ADAPT, OVERCOME...right? Yes I will still order the right tools. But to break loose a stubborn pulley or if you can't wait for the tools like me, it did work well. I am ordering the tools though. I contacted the gentleman for them.
73m819
328
gainesville, ga.
Something like this "next time say how do I do a adjustment for my air compressor belt"
Don't worry, we let ALL the non emg. helps know thay should use a different title in there thread.
doghead
4 Star General /Moderator
1,191
Title edited
