- 827
- 224
- 43
Replacing Front Axle Air Pressure Switch
Hey All,
I'm having a problem with my front axle light on the dash not working.
I tried my front axle engagement switch today, and the light did not come on. So I turned the engine off, and I could hear it engage when I moved the lever. But the light below the lever did not come on.
So after checking wires, changing the bulb etc. Connecting the light directly to a power source, it came on and lit up fine. I finally decided to remove the entire air shift switch assembly and take a closer look. After doing so, I took it in to the work bench, and removed the pressure switch that the light wire connects to. When I did, I found a bunch of gunk inside, so I cleaned all that out of the assembly. And I tried to clean out the pressure switch, but it is sealed.
I then tried to bench test the switch by connecting it to my air compressor, and then use a voltmeter to check for continuity. I tried several times, but got nothing.
So I need to get a new pressure switch, and I started looking on Eriks. However, after doing some searching, I'm not really finding the pressure switch for the front axle air shift engagement anywhere.
What I did find is a "brake light pressure switch" It looks almost exactly like this switch except for the terminals, which wouldn't be a problem as I can just change the wires to the correct terminals, as I already have the military connectors.
Here is a link to this "Brake" pressure switch:
Brake Light Air Operated Switch, M35/M54/M809/M939 etc, 11602160
Does anyone know if this switch will work and operate correctly for this application? I don't see why it wouldn't. The only questions I have is if it has the same thread size...
If anyone knows about this, any input would be appreciated!
Thanks!
UPDATE:
Hey All, I received the "brake" pressure switch today. It has a 3/8" inch size threaded fitting, where the original pressure switch was only 1/8" inch threaded fitting.
So I had to take a trip to to home-depot and pick up some adapters, to adapt it from 3/8" to 1/8" They didn't have a single adapter that work do it, so I had to use a couple pieces to get to the right sizes. As long as you have the room, its no big deal, just use a good thread sealant tape, and properly tighten.
If you don't have the room for the extra length gained by adding the adapters, you might consider adding a 90 Degree elbow like I did. I had already installed this just to have plenty clearance between the switch and a 12v power socket I had added. But it now became necessary to have the 90 when adding the adapter pieces to this new switch.
All in all, it was easy to adapt, and easy to install. And it works perfect!
This is an easy fix to replacing the old pressure switch for the front axle engagement switch light. And its also much cheaper than buying the whole front axle air-shift assembly at around $150. This replacement pressure switch only costs $45 from Eriks, which is the link in my original post. Might even find it cheaper somewhere with further searching
, or you might even have an extra.
After the install I fired up the truck, and as the air pressure began to build up somewhere around 30psi, I flipped the Axle Shift Switch Lever. The light came on just as it should. I ran the truck a few more minuets, and let the pressure build up to full. Tried the switch a few more times, and it worked every-time. So we shouldn't have any more problems with the axle switch after this repair.
I know how you guys like photos (just like I do)
So I took a few shots of the parts, install, and completed setup, and posted them below. Thanks Everyone!View attachment 326629
Hey All,
Thanks!
UPDATE:
