Me and my brother drove 375 miles on Thursday to recover a Deuce. The owner said the brakes did not work and that it needed a airpak so i brought one and wheel cylinders and a power bleeder. The truck did not need either, all i had to do is bleed the brakes and they worked great. So I was glad that the brakes where a easy fix. So i started checking over the truck and checking the fluids in every thing and it was looking good. I got to the tranny and it was a little low and pretty black so topped if off and then changed the motor oil. Also pulled the inspection plate on the tranny and greased the throwout bearing because it was a little noisy. Had one low tire that would not take any air so me and my brother jumped in to head to the tire shop and take it for the first drive. So we got going and when we hit 5th gear it sounded like someone way banging on the floor with a hammer and was vibrating BAD. So needless to say the truck was not going to make the trip home 375 miles in 4th gear at 40 miles per hour . I had not payed for the truck yet or signed any paper work and was mad that the owner had not said anything about this problem that he had to of know about!! So we drove back and talked to the brother of the owner because the owner had left . We told him what the truck was doing and he says " Oh he didn't tell you about that". I later talk to the owner on the phone and told him that 5th gear is out and that the truck is not going to make it home and that i might not buy it. The owner then try's to tell me that the noise is because the tires on the back are not all the same height and the sprag is doing that . So he asks are you just going to leave and go home . I told him not much else i can do today so he tells me to make him a lower offer on the truck . So i told him I would have to do some research on the transmission on how much it will cost to repair or replace and find someone to ship it and find a cost for that to.
The truck is rust free and has a tarp and bows , newer paint, hummer seats has com gear installed but no radio a m66 gun turret , tires are ok a couple back tires have a little dry rote, newer soft top , no major leaks and runs great .
Only bad things are that 5th gear is out and it has a sprag t-case.
I'm still going to buy it just have to have it shipped. ?? It has cost me 200 in gas to drive there and back for him being dishonest too. Where is the best place to find a used transmission or parts? Trying to find what the cost is going to be so I can make him a offer.
