- 2,186
- 87
- 48
- Zimmerman MN
The TM's say to coat one side of the axle flange gasket with GAA grease before installing. Of course they don't specify which side! Which side????? or does it matter not?
Yeah I think you are correct. So it semi stays in place when you put the axle in and move it for alignment too.I'm going to assume that the grease is just to keep the gasket from sticking so the next time you take it off it will not rip. So either side. I would put it on the side that tuches the hub so the gasket will stay with the axle.
