I have an M35A2 that all the lights work on except the turn signals. I replaced the original flasher box on the truck with a used but working box. The turn signals worked, but only for about a month. During that month I only drove the truck for maybe 4 hours total. I thought that maybe the used flasher box was near it's end and I was happy to get some use out of it. I figured the best thing to do was to just buy a brand new flasher box. I did that, bolted it in and like magic....the turn signals worked again. I thought I was done with the signal problem.
The first time I drove the Deuce since replacing the box and the turn signals only worked for maybe 6 turns and stopped working again. Is there anyway that my wiring harness or something other than the box is causing the flasher box to short out?? The ground wire on the flasher box is clean and secure. Anyone else had a similar problem?? Thanks.
Mark
Mark
