want to add am/fm radio
Kenneth Cole
Wapiti Wyoming
Good day
I want to add an AM/FM either tape or CD to my M37 under dash. Any one have any good suggestions as to brands or what ever?
Thanks for the help
Ken
nattieleather
148
Cleveland, OH
That's the biggest thing is getting the 12V hooked up correctly to power the radio. I would do a search for a radio that maybe meets Mill standards for shock/vibration and moisture. This way it has a chance working 6 months down the road.
shootist
RI
Hi Ken,
Get yourself a good step down inverter.
For a stereo go with a marine grade system
There are several manufactures, check boat/marina shops
Near you or surf around.
As far as mounting under dash- not much room.
But , you can use a marine bracket ,similar to a cb radio bracket
Just make sure you use the rubber bushings on the mount
At the radio. You could also mount same radio in a 5.56mm
Ammo can under dash and close cover when not in use.
Or get a remote version, mount radio under seat near battry box
And place remote somewhere on dash, And finally an easier set up would be an iPod/iPhone with radio app
With mounted external speakers.(no need for antenna etc)Power
Your iPod from a cigarette lighter you have connected to your inverter.
I use the iPod method,
ke6rwj
creating havoc one broken bolt at a time...
286
151
Alabama
Hi Ken,
This advice is dead on. I second it all fwiw
