Hello from Germany,I just did this with mine. If you can get a little creative withholding the bolts in your wrench. You can just drop the heater and go through the heater vent intake.
I don't think you be able to do about these dropping the heater some.
Hello from Germany,
what do you mean with "through the heater vent intake"?
Do you mean that moveable clap outside in front of the windscreen rh-side?
Ciao
Snoop
Hello SnoopGreets from Hanau
Ciao
Snoop
Hi J.P.Hello Snoop
whats the place look like now..
is the Park restraunt still there?
Hutier Kasern is where I was at for 4 years..
J.P.
Rivnuts or blind nuts don't take to high torque well, unless you use the keyed ones.I tried taking the windshield bracket off and knew I would loose the bolts. I thought , What the Heck, I'll put a nutssert in the hole. and just put new bolts in it. Didn't work, ended up removing the heater. I am not that flexable any more. Job took two days![]()
