emergency air connection
groundog
wittmann,az
:driver:on my 915A1 i get air from the emergency connection on the front but not the rear---suggestions?yes the valve is open but still no air from the rear---
WillWagner
3,163
Monrovia, Ca.
Valves are backwards. :p Trace it back to the source. maybe it's been plugged or pinched.
KsM715
142
St George Ks
Did it have a cover on it when you picked it up? Mud daubers (wasp like bee's) may have clogged it up. If you have them in AZ.
*edit* Just to satisfy my curiousity, you do know that some of theMil valves are backwards from the civy counterpart. (handle inline with the airline is closed)
3dAngus
102
Perry, Ga.
I had the same problem, came on here and reported, and was told to look for dirt dobbers clogging up the holes too. Sure enough, there was mud in there. I got a screwdriver and scraped it out, and the air was just a flowing. I almost couldn't believe it, except a SSer was the source. Cool stuff.
groundog
wittmann,az
at the glad hand----yes ---you are right about valves being backwards---but still no luck----I am going to remove air line from glad hand and check for air and if no luck I guess its under the truck I go and follow lines---glad I discovered this ahead of time
NDT
7,393
Camp Wood/LC, TX
On the 915's, you have to apply the trailer air valve for service/emergency air to be supplied to the rear glad hands.
Danl
Lyman Maine
Danl M915A1 case farm tractor
Ok on the m915 driving with no trailer and all air conect sealed, or caped off . how or whats the best way to run the trailer brake valve, trailer brake on or off?
73m819
329
gainesville, ga.
THE -10 will have the answer to this SIMPLE truck operation QUESTION
groundog
wittmann,az
:driver:PRETTY SURE I TRIED WITH BRAKES OFF AND TRAILER BRAKE VALVE ENGAGED BUT WILL TRY AGAIN--I KNOW ON MY 931 I HAVE TO HAVE AT LEAST 85-90 LBS AIR TO MAKE TRAILER BRAKES WORK---THANKS FOR ALL ADVICE---EACH NEW TRUCK IS A LEARNING PROCESS
