- 1,626
- 704
- Central NY
In tearing down the siezed Level Wind and Cable Tensioner, I have discovered that the Sheave frame extension #20 shaft was never drilled for a grease fitting #16. No lateral delivery hole to needle rollers either. And no - the old grease is not solid thus hiding the hole. I even ran a lathe center drill into the end of the shaft and **** near burnt it out a it is so hard! No Hole!
There is no way to grease the lower needle bearing #22 !
So - go feel under the trolley of the swivel to your top roller for grease fitting and see if I am alone in this.
#'s are from page 420 of TM9-2320-260-34-2
Have already stripped all needles out, cleaned and polished, same for the outer race and repacked. But that won't last forever...
