List of part numbers for NHC oil cooler change
ranchhopper
139
south elgin illinois
Here is a list of the part numbers for the items you will need to do the oil cooler change in your five ton sooner or later. I just got done doing this with my truck and I got the cummins part numbers off the parts themselves. Oil cooler unit P/N 110848, O-Rings (2 required) P/N C3389249, Brass retainer rings (2 required) P/N 110827, Gasket (1 required goes against block) P/N 3008017. There is an outer gasket where the end bolts to the cooler housing I made my own for this so your on your own here.
ranchhopper
139
What do want pics of them in their packages I just finished 12 hours at work then got the thing back together tonight the parts came in this afternoon no time for pics.
ARYankee
33
Benton, AR
I'll have to check my 5 ton parts search database and see if these are listed in there. If not I'll have to add them.
