rickycotte
- 0
- 0
- San German, Puerto Rico
Before posting my request for information to this honorable community, I must say I did search on the TM before daring to ask for information. I found no information on this. Maybe it is there but I did not find it.
Ok, that aside, I would like to know the reasoning for the warning on the dash placard against using LOW RANGE in REVERSE. It lists all the permissible speeds for the different gear combinations but warns against using low range while in reverse gear.
Any explanation on this? Is reverse gear ratio already so low as to put too much strain on the powertrain by going to a lower ratio?
Someday, someone may need to get out of a really tight/steep spot in reverse, with your rig loaded, off road without any other recourse.
Your sharing of knowledge is greatly appreciated.
