Terracoma
- 15
- 18
- Albuquerque, NM
Amen, Jerry... I grew up mechanically disinclined, and am now a big believer in "teaching men to fish", so to speak.Got to nurture the young.
Do yourself a favor by replacing the oil, oil filter and the fuel filters first. Clean the screens on the fuel pumps. Then try to start the generator. Taking short cuts on preliminary maintenance of a newly acquired gen set is asking for trouble. Just ask sewerzuk about that loose nut or bolt that got ingested by one of his new acquisitions. Once you've cleaned and changed these items, prime the fuel system and check for proper return. Then, and only then, try to start.
John
I changed the filters and oil - bled the system and she fired. The oil filter housing was a bronze unit from southern automotive wholesalers and I could not get it to seal, so I robbed the one off the 003 that I had sitting there. The throttle cable had been routed wrong and was binding on the injector cover door.
Appears to be running good. Thanks for all the help everyone.
Now - about the mep-003: I looked in the tank and it appears a tad rusty. Anyone have any experiences with that? I would say its sat empty for some time and condensation has done the damage. The screen in the tank insert also had some holes in it.
Try to clean it - or is that a lost cause?
You forgot to mention skin, Wear gloves. It will dry out your skin very fast and I am sure it is putting bad things into your body in the process.Xylene is a powerful solvent for many organic substances. It will readily dissolve most paint, synthetic plastics and elastomers. If you use it, avoid getting it on these materials.
