keefer
- 0
- 0
- gloucester/virginia
ok. its been a year trying to get this truck to work. its starts and runs fine for several minuets and shuts down. the fuel system is definitly the problem. the fuel system has been replaced from the injector pump all the way back to the sending unit. nothing is original between those two parts. the fuel pickup filter is new and the tank has been drained and cleaned out.
heres the deal.....if i take the fuel supply line off of the sending unit and put it in a jerry can, the truck runs great. i drove it several hundred miles like that. as soon as it goes back onto the sending unit, i get the same problems. i tried driving it with the gas cap off incase something isnt venting properly, with no luck.
could my fuel cap be bad? i dont see any evap canister so im assuming cucv's dont have them. i talked to an experienced mechanic and he said it woulnt likely be the sending unit itself. what could it be? please help! i dont want to ride my motorcycle in the snow again this coming winter. I need my truck!
