Ready Welder
gimpyrobb
dumpsterlandingfromorbit!
27,787
778
Cincy Ohio
Looks like only one person posted that he has used it, and for sheet metal. I would like to know about it overall. I have a small mig and would probably use this for thick steel.
Heath_h49008
103
Kalamazoo/Mich
If you already have a small wire welder, you have a machine that's better than this. The benefit of the ReadyWelder is portability, not quality of the bead or the thickness of the metal you can weld. I would be very surprised if it would weld anything the cheapest 110 wire rig couldn't.
My welding instructor was pretty impressed with the inverter welders. His opinion was "It's all about the power supply and duty cycle... the rest is just sales gimmicks." Inverters have the best power you can get.
I want a machine to get me into spray-arc something fierce. But right now, it just isn't in the budget. (and if Santa is listening... a Tig machine, and a laser table.)
Have you considered a good old Lincoln "Tombstone" for the heavy stuff? They are about the best bang for the buck you're gonna find for doing steel in medium thicknesses.
m16ty
225
Dickson,TN
Personally, I have my doubts about it on thick steel. The way the website sounds it will weld anything but the crack of dawn.
I also wonder, even if it will weld thick steel ok, if your batteries or deuce charging system will be able to hold up.
Heath_h49008
103
Kalamazoo/Mich
I'm certain if you're good enough, and willing to make enough passes, you could weld a battleship with a Harbor Freight flux gun. :)
(I think that's what the Chinese are trying with their new Aircraft Carrier.)
gimpyrobb
27,787
778
Cincy Ohio
I have a 275A buzz box but its ac only. I also have a Lincoln 3200hd 110v mig. The small size of the ready welder is what is attractive and I could use it with the deuce's slave cable plug if needed.
Heath_h49008
103
Kalamazoo/Mich
In that situation where you can't reach any other welder... yes. I could see the readywelder as justified.
But only for sheetmetal.
If you have to weld suspension/frame/rim/plate or anything thicker than about 3/16, I would say you were better off with a DC stick weld running off the batteries and using a 6010/6011 rod for thicker material, and 6013 for thinner sheet.
You have a solution looking for a problem.
Of course, it's your money and that Readywelder looks a whole lot better to haul out and use than an old stinger and a couple of cables! (But I would keep those welding rods and stinger handy for the thick stuff anyway. 2cents)
If you get it, I would love to see the beads she throws. Keep us in the loop either way!
robert c neth
Banned
233
girard pa
we use a 110 mig and a lincon welder ,they also work well with our 5500 watt generator .we can weld anywhere we want but they are a little bulky.getting home is what counts.
