turbovr6jetta
- 0
- 16
- Bellingham Wa
I got my 395s on today, so I figured I would share with the class. I will start off by saying that a "tire slide hammer was the absolute key to removing my old 9.00's. An excavator smashing the tire while I beat the bead with a pick and pieces of angle with a sledge and it would not budge it even a little. I did happen to start with the most stuborn tire. After the tires were removed (no pictures sorry) I sand blased the rims. I didnt worry about making them perfect I just wanted to clean them up and get fresh paint on them primarily the insides due to the rust issue that caused my difficult time removing the tires and hopefully making the install a little smoother. When the paint was dry I went to work, I used 10.00/12.60 tubes and 8 inch flaps. I filled the tubes just a little and stuffed them in the tire then flap....... Threaded the stem worked the wheel in yada yada. I used a cherry picker (engine hoist) to pull the wheel up out of the tire enough to put the lock ring on. I stuck the lock ring in non notched side first and just stood on it in the right spots to get it to pop in sometimes using a dead blow to finish her off. I used a excavator bucket to protect me/everything from a ring blowing off. I also used a locking tire chuck so I could get some distance while filling. Everything went together real smooth and really wasnt too bad of a job less picking up the wheel/tire. I mounted them just as stock less the inner tire one the rear axels. I kind of like the wider rear stance for now. I also just used the stock budd/thimble nuts to hold the wheel on. I most likely will order some lug nuts that fit the wheel stud just for a nicer look. Alk in all im glad I spent 24 hours in the last two days on this project. I cant wait to drive it... Oh and if no body ever hears from me again take this and publish it on what not to do!
