Hi,
I just finished repairing a couple of M35A2 Flasher modules, and thought some might be interested. The problem is the circuit board is single sided, and the manufacturer drilled the holes too big. That means that if the component leads are not bent over onto the board, the potting compound will stress and crack the solder that bridges the gaps (over the too large holes).
The challenge in repairing potted blinker modules is to get the potting compound off of the circuit board. That is fairly easily done, if you have a source of hot air (some would say that I AM a source of hot air, but I digress...) I use a hot air work station for repairing surface mount circuit boards as that source... but you could use an oven set for 250F.
The potting compound gets soft as eraser rubber if it is warmed up, and it can be picked away carefully with a small bladed screwdriver, or an xacto knife.
Once the potting is off, you will be able to easily see the broken solder joints, and resolder them up using plenty of solder. Use 60/40 solder, not 63/37. 60/40 builds up better than 63/37.
The picture is the board after I have repaired the bad joints. It is now blinking along merrily.
-Chuck
My next project is to fix an alternator regulator that has the same failure.
-Chuck
