Yes purchased. The reason why I want to stay with 240 is because I have a Miltric DeContractor setup already and the whole box is from that source.Lextreme - lets simplify this need.
1. What are you going to run with the gen
2. Are you planning on running those accessories while going down the road"
3. What is the most amperage you need at any given time ?
4. While parked - engine NOT running - what power demand will you need ?
good place to start.
Sent Ya a PM as well and the reason for asking
Ah okay. Was wondering about that. Sounds like an interesting setup.I also have a 240V electric stove too.
That is correct. Most likely I will do 1:1 ratio because I dont really need 5k watts. AC require about 1.6KW/H. I can always lower the generator pulley to increase watts. Make it safe first.... Dont want to over load the system.Your AC output frequency is going to vary widely with this configuration as you drive, and I don't think the motors in your air conditioning unit are going to be happy for very long using the proposed system. I think it would be wise to consider another way of accomplishing your goals.
