I recovered My new M116A2-MEP-002A 2007reman generator set. I have down loaded the TM's and have perused them. I have also read and subscribed to various generator threads and gotten familiar with do's and DONT's of MEP-002A operation.
So this pre-evening I went out and opened the hind-end curtain and sat and looked at the generator set an became one with it. I found a certain energy in the experience.
I found the throttle, the ground strap, filters, checked the oil, looked at the lugs where the juice flows, contemplated how I want it set up, who is going to install the lockout switch on the pole.......
I 've decided I am going to clean all the ground strap connections and dielectric grease them as well as add another ground strap from the gen set mounting lug directly to the copper rods that will go into the ground and the pole. I am also going to do the checklist from some of the threads and out of the TM's prior to staring it.
I am wondering about how the juice will go from the gen set to the tansfer-lockout switch to the meter box but that is what professional electricians are for. I am wondering if a breaker box is in order on the trailer? Or a big plug in cable, Hmmm. I can't wait for all the ducks to be in a row and stars aligned and when the
so I can fire this rig up and see if it works!! I know one thing, DON't IDLe IT, RUN IT at 60 cycles!!! It has 6 hours on the clock so I'm hoping the techs and the guys who used it before I got it didn't break it in those 6 hours.
I just used the GL pictures cause it's too dark to go take new pictures.
and I figured I am going to put a cable clamp on the throttle cable when it is in about the 59 and 3/4 cycles while it is running no load so it won't get idled down. I also figured that at that setting there is room to bump it up as the load is installed. I also figured I'd use it every couple of months to keep fresh fuel in it and keep the moisture out of it.
