BEANBELLY
- 0
- 0
- eastern wa.
is it better to use a 24 to 12 volt reducer or converter. want to add two radios, intercome several lights and fan for sure to my deuce. thanks for any help beanbelly![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have two 720 watt Pyle converters now and they work great but I may eventually add an electric winch and that will necessitate a 12 volt alternator. Does anyone make an alternator mounting bracket to fit the Cat 3116 in my A3? I have seen posts where members have fabricated one up but am not aware of anyone who sells them.Personally, with the amount of stuff you want I wouldn't waste the money on an inverter or any other gadget to maintain your batteries.......
Get a hold of tmAmerica(he's a member on here) he makes a bracket that will allow you to add another alternator to your truck......bolt on very simple and you can use any cheap GM alternator, mine cost me a whole $32 from Autozone(new).....then go to Menards and spend another $37 dollars for a nice lawnmower battery(new)......very nice size so fits dang near anywhere.....oh yeah you also need the new belt from Autozone($5)
You now can pull ALL the freakin power you want and never damage your batteries to run the truck on.
Absolutely the easiest thing to do on the truck....you will find that after you have it you will start adding all kinds of stuff.....how about a plug to charge your cell phone(get where I am going)......you won't regret it and it is all able to be had for less than a GOOD converter that would handle all you want to run.
Not sure I understand your question/English.Hey guys, i read above about adding the other alternator. could you just make a mount for a 12v battery and hook that (3rd?) up to the one that would charge 12v? ( in my case it would the the driver side alternator on the m1009, then you could run all your 12v off that battery?
Really? There isn't a resistor in the circuit for low speed fan?This would really help in the case of the m939 series trucks since the heater fan low speed is just 12vdc pulled off of one of the batteries. For this reason I never use the low heater fan speed.
