Steve1031
- 3
- 0
- Dundee, OR
Put the latest Trucklite LED headlights in, replaced all the reflectors and side marker lenses, painted the bed on the inside as well as camoed the troop seats to match the truck.
Added a surge protector to the lines supplying the ABS ECU.
Which surge protector did you use ? Where did it mount? I would like to protect the ECU also.
As long as you can do the basics you can learn the rest. Glad to hear shes a runner again.After the heat wave the last 21 days (over 100 for 21 days) I was unable to start the m923. I tried to charge the batteries for about five days....but no luck. Tried to jump it with the Sheriff Dept. hummer, but no luck. Someone said that wouldn't work after I tried it and it didn't. Took all of them out and two showed no good when tested at the battery shop. Two new ones later ($170.00 each for tl6's) she's up and running again. A 30 mile test drive showed alls well again.
No I'm not a mechanic can you tell?![]()
